CPU core Temp Difference
Solved by JohnnyGrey,
This is common among Ivy Bridge and Haswell chips. I'm shocked you just now noticed this. The only way I've seen this resolved is delidding the CPU and using new thermal compound. You could always try remounting the block to see if it helps a little, but I think delidding is the major solution. My air-cooled rig does the same thing.
Ishikudeska ·
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
