8 minutes ago, JD PEdreira said:
What do you guys think? I want a good 1080p experience. (P.S. I'm poor)
Can someone recommend a good, pretty, cheap 1080p monitor? (Around 120-150$)
https://pcpartpicker.com/user/pedreirajd/saved/#view=myQmGX
The build is pretty solid, although now is a very bad time to build a PC. If you want a good gaming experience, buy any monitor under 5ms latency. In this price range, it'll be probably a TN panel, which is good, if you don't work as a designer and you don't need very good colours. Check some 75Hz monitors and buy Asus, Benq or Aoc those are good brands. I would sugest you Asus VS247HR, but there are planty good monitors in this price range
https://linustechtips.com/topic/798379-first-build/#findComment-10045705
I'm pretty sure 75Hz monitors are just factory overclocked 60Hz monitors, and at 1080p, IPS is quite affordable, with IPS 24" monitors for only around 115$
https://linustechtips.com/topic/798379-first-build/#findComment-10047535
Good build. Wait for RX 470s and 570 prices to go back to normal, replace the 1050 Ti with one of those, pair that with a FreeSync monitor, and throw out the DVD writer,
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/798379-first-build/#findComment-10047968
I'm using a BlueRay reader because i'm going to be using it also as a Home Theather, I know optical drivers are almost obsolete by now. Thanks anyways
https://linustechtips.com/topic/798379-first-build/#findComment-10049703
