  • 5 weeks later...
  • 2 weeks later...
  • 1 month later...
On 8/4/2017 at 11:09 AM, niccaa23 said:
any updates on the card? @Exist2Resist :)
Hey yeah sorry got a little busy.
Card is good, I mostly use it with OBS, and stream on YouTube or capture.
They HDMI switch is digital, and it's either one or the other, but the beauty of it is you can do scene switching in OBS.
There is a slight delay between the scenes, so if you plan on using it like that a transition is probably a good idea.
OBS sees both HDMI inputs on the Card you can select them in the software.
A first gen i7 uses  ~60% CPU when streaming decoding.
I have a dedicated box so it doesn't bother me. I also have a 5930k but that's my gaming box so I want to keep it out of that.
I had to also pick up a 2 port HDMI switch to strip the HDCP from my receiver.
Now I can stream my Switch and PC on Youtube.
I have had a couple crashes but I think it's more Windows 10 than the driver/hardware.
Good card at a good price, I recommend it.
https://www.youtube.com/channel/UCvSkLehA76ZdR7eOhawLBBw
All the Zelda BOTW capture are done with the capture cards @ 5000kb/s
https://linustechtips.com/topic/797534-capture-card/#findComment-10479355
  • 5 months later...
Hi - just happened across this as I was looking for pricing on the Pirect Uldra-P60.
I see here you are using similar to the application I was considering (P60 capture/stream to OBS).
Do I understand you correctly, however, that you can only use one HDMI port inbound at one time?
I was hoping to get three of these cards so I could capture/stream 6 HDMI port In at the SAME TIME on OBS.
I saw a video showing what you confirmed: that you can see both HDMI port as sources in OBS at the same time.
However, if I read you correctly, you are saying that I would not be able to preview/stream/record BOTH HDMI ports Inbound at the same time--is that correct (I hope not!)?
Thanks in advance!
https://linustechtips.com/topic/797534-capture-card/#findComment-11106423
