CPU fan at 100%
Solved by Connor Price,
2 minutes ago, dnf said:SpeedFan isnt doing anything for some reason, gonna check BIOS...
SpeedFan is a bit of a pain in the ass to use. You have to go into configure, then advanced and try one of the chips from the drop down menu. For me, it's the top one. Then you select manual on the PWM modes, seeing which one controls your CPU fan and which one controls the case fans etc.. Then you go back to the main screen and change the speed.
