I got a ryzen 7 1700 a little while ago and was immediately drawn to the stock cooler. AMD did a great job putting a ring on it?, speaking of I fell in love with the RGB ring and AMD logo on it and was wondering any suggestions on how to mount that to a tower  styled air cooler such as the deepcool gammaxx 400? I was about to use zip ties but realized those melt at about 75°C or ~150°f any suggestions on how to mount it? The mounting bar I got with the cooler does not fit.
https://linustechtips.com/topic/796952-ryzen-stock-fan/
2 minutes ago, FTL said:
The stock fan is too small to fit onto your aftermarket cooler.
I know it is and that is why I'm looking for alternative mounting options, I'm not doing any over clocks so having the smaller fan won't hurt me that much. Possibly 2-4°c
https://linustechtips.com/topic/796952-ryzen-stock-fan/#findComment-10031165
Get some stiff wire and use that instead of the zip ties?
https://linustechtips.com/topic/796952-ryzen-stock-fan/#findComment-10031174
Get one of those assortment bags of zip ties from a auto parts store. They will not melt unless your PC is on fire.
My Build:https://linustechtips.com/main/topic/795406-mini-itx-build/   PSU TIER LIST
"The difference between genius and stupidity is that genius has it's limits." - Albert Einstein
"If my doctor told me I had only six minutes to live, I wouldn't brood. I'd type a little faster." - Issac Asimov
"Headward, free now to rise." - Principal Vagina
https://linustechtips.com/topic/796952-ryzen-stock-fan/#findComment-10031185
