Hey Guys,
So the dealio is this. I'm trying to run a powershell command in a cmd script of mine.
My power shell knowledge is very limited, so I understand this may just be a simple fix to some you :)
This is what I am attempting to run:
powershell -command Import-StartLayout –LayoutPath C:\Windows\Temp\Startmenudef.xml -MountPath $env:SystemDrive
The error I get back is attached...Capture.PNG.fa56b481d52e8faf93de6bafaf6758b7.PNG
I have googled and tried all sorts of different quotation marks and parameter definers, but I can't seem to get it to work. The command itself runs fine in admin mode powershell, I will also attach a screenshot of this... Capture1.PNG.75c43327816623775c69646a319be705.PNG
Any help would be greatly appreciated.
Thank you.
- Samuel
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/795765-powershell-comand-in-cmd-script/
On 6/20/2017 at 9:35 AM, SamuelJE said:
-snip-
can you please post the contents of the Startmenudef.xml file so I can try to reproduce your issue. Also in the meantime try to put C:\Windows\Temp\Startmenudef.xml in quotations like this:
powershell -command Import-StartLayout –LayoutPath "C:\Windows\Temp\Startmenudef.xml" -MountPath $env:SystemDrive
And the final question is, are you running this command as admin? If not try doing that.
Thanks!
Yep I'll attach the file. I have tried quotation marks but to no avail, and the script requires admin rights to run, so it is always started in admin (it actually requests it).
What I since have found to work how ever is this
powershell -command "& {Import-StartLayout -layoutpath C:\Windows\Temp\Startmenudef.xml -MountPath $env:SystemDrive\}"
But it comes back with a slightly less strange error and still doesn't produce the results I'd like.
Thanks again.
Regards,
 Samuel
LayoutDef.xml
Samuel Edwards
HDD    -    2TB WD Green
