I have a brother MFC-J55200W. The system I am trying to use is Linux Mint. I know nothing about hooking up a printer to Linux Mint.
Please Help
Chase B
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/795646-help-hooking-up-printer/
Please Help
Chase B
  1. Go here (http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=mfc495cw_all)
  2. Choose Linux for OS family
  3. Choose the "deb" option
  4. Install using instructions here (https://askubuntu.com/questions/40779/how-do-i-install-a-deb-file-via-the-command-line)
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/795646-help-hooking-up-printer/#findComment-10016051
36 minutes ago, bob51zhang said:
Promblem
Chase B
https://linustechtips.com/topic/795646-help-hooking-up-printer/#findComment-10016236
1 hour ago, ChaseB said:
Promblem
Sorry, I don't see a picture.
https://linustechtips.com/topic/795646-help-hooking-up-printer/#findComment-10016654
