Hello guys. I built my first PC today and im worried about the CPU cooler i installed . Its the stock cooler from ryzen and it seems to be firm but im not sure.Is there a way i can check if its firm and also are there any programs that i can test my PC to see if it work as it should.Thanks
https://linustechtips.com/topic/795626-my-first-pc-build/
as long as it can support its own weight you are fine
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/795626-my-first-pc-build/#findComment-10015855
19 hours ago, XspazzayX said:
I havent even turned it on yet. My ram sticks still havent been delivered but i was and am really worried becasue the build was really sloppy.
You can't real tell if there's problem or not before turning it on. On first boot go to BIOS and check how temps are there. If they are climbing rapidly over 50C, you have bad mount. Saying from experience, I had bad mount on Intel stock cooler and let temps go to 60C (which was fine for CPU) before turning it off and remounting.
Could you please tell me what direction should the cooler be in. I faced it so that the RYZEN CPU LOGo matches the AMD logo. Is that how its suppost to be
Doesn't matter. Its down-draft cooler. Works all the way around.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/795626-my-first-pc-build/#findComment-10021055
