Power connectors
Go to solution Solved by W-L,
1 minute ago, bazookaman36 said:
I'm building a PC with a MSI H110 Gaming motherboard, and I'm trying to plug in the case fan. It has a three pin power connector, but I can't find the place to plug it in on the motherboard.
You can plug 3 pin fan connectors onto a 4 pin motherboard header just be sure to configure it within the BIOS to run under DC voltage control or it will run full speed if it's default is PWM (4pin)
-Moved to CPUs, Motherboards, and Memory-
https://linustechtips.com/topic/795112-power-connectors/#findComment-10009890
