Buying first AIO
Go to solution Solved by knightslugger,
The AM4 brackets for the Hydro Series AIOs are available. You may need to order it seperately, and I believe Corsiar has been shipping them to owners for free.
I am currently looking at a GIGABYTE GA-AX370-Gaming K5 and I am looking for a decent AIO on price (as I'm coming from a CM Hyper 612 V2).
ATM, looking at a Corsair H100i V2 but I'm getting conflicting reports on the AM4 brackets (between Amazon and Corsair themselves) and I'm looking for 2nd opinions.
https://linustechtips.com/topic/793251-buying-first-aio/
I have R7 1700x paired with H100i v2. Great cooler, used it for my FX 6350 before the upgrade.
Unless Corsair started to put the brackets in new boxes, it won't have AM4 compatible brackets. You can get a pair free from Corsair. There is a code you use, but forget it now.
Great cooler.
https://linustechtips.com/topic/793251-buying-first-aio/#findComment-9989815
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/793251-buying-first-aio/#findComment-9989822
