Hello there!
I have been wanting to change out the CPU cooler on my main rig for quite a while now. It's a Zalman LM-315 (An Asetek rebrand). It does its job well enough, but since this computer is storing some sensitive data on it, I thought it would be better to look into an air cooler. Having it be quieter would be lovely as well, as the pump is pretty loud on this cooler. Is there anything 40 or below that you think would work? Thanks!
Almost forgot to mention the case, which is a Node 804, with 160mm of clearance.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/792367-cooler-upgrade/
