Looking to make my first pc that is $500AUD. (I'm willing to go over for a optical drive)
The system is mainly going to be used for gaming as well as day to day work.
I'm planing of running 1 moniter but might run 2.
I have the moniter (ASUS VS197T-P 18.5" WXGA 1366x768 DVI VGA Back-lit LED Monitor ) and a keyboad and mouse
PLEASE MAKE SURE THE PARTS CAN SHIP TO AUS. Thanks. Also if you can see inside the case from the left side that'd be great
https://linustechtips.com/topic/792134-500-aud-first-system/
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($77.00 @ Umart) - may need BIOS update
Motherboard: ASRock - H110M-HDS Micro ATX LGA1151 Motherboard  ($72.00 @ Umart)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($75.00 @ Centre Com)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($63.00 @ Shopping Express)
Video Card: Gigabyte - Radeon RX 460 2GB WINDFORCE OC Video Card  ($119.00 @ IJK)
Case: BitFenix - Comrade ATX Mid Tower Case  ($47.00 @ Umart)
Power Supply: Corsair - Builder 430W 80+ Bronze Certified ATX Power Supply  ($62.00 @ IJK)
Total: $515.00
Generated by PCPartPicker 2017-06-12 20:08 AEST+1000
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976673
Total: $515.00
Agree with this build apart from the PSU. Those PSU's are nutorious for being trash. I would change it to the ones with the black text, or something like a EVGA B1.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976710
No, the old Corsair CX series are fine. People like to exaggerate.
And to be honest, the EVGA B1 series are not any better.
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976715
1 minute ago, Kapila said:
If i was to get a different one which one should in get
The Corsair CX430 is fine. The Corsair CX450M would be even better but that's another $20.
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976730
EVGA B1 (500w will be fine) or the CX550M.
Any corsair PSU with green/white writing is trash. The ones in silver / black are great.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976735
No, it's not. These PSU's are nutorious for having several problems, the voltage regulation is trash, it had medicore build quality and has one of the shittiest hold times there is. Even the garbage in-win psus have higher hold up times.
Do not buy the corsair CX430.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976747
I am able to be a little bit flexible with the price so i'll get the CX550M
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976749
It's a great PSU. You don't want to cheap out on a PSU, when PSU's die they tend to take other components with them.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976755
You call the Corsair CX430 trash but then recommend the EVGA 500B when it's not any better?
You say that the voltage regulation is trash... JonnyGuru's hot box testing for progressive load tests saw the 12V rail output ranging from 11.82V to 11.95V, which is well within the ATX spec and is rather quite good. 5V rail saw 4.99V to 5.10V which is still good. 3.3V saw 3.25V to 3.31V which is still decent.
The build quality, at best, is comparable to the EVGA 500B. And the hold-up time is still within Intel's requirements...
So yeah, I find your use of the word "trash" to be over-exaggerated. There are much worse power supplies. The Corsair CX430 is not the absolute best power supply on the market, in fact it's quite mediocre, but it's not as bad as people made it out to be. The EVGA B1 series by HEC are not any better.
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976798
500b still has better hold times, the cx430 is far below atx regulation... below inwin infact
besides I reccomended the cx500m in the end (newer, non garbage one)
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976823
ATX specification says the 12V rail must be within 11.4V to 12.6V, the 5V rail must be within 4.75V to 5.25V and the 3.3V rail must be within 3.14V to 3.31V. The CX430 is well within those specs so I don't know why you're saying it's not.
You can do far worse with the hold up times and it's not the end of the world... it's not as if we're powering a high-end build with a GTX 1080Ti... we're powering a G4560 + RX 460 which has extremely low power requirements.
BTW, the CX500M is one of the older models that you call "trash".
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9976859
CX550M* which is one of the new ones.
and it's irrelevant, you can get far better PSUs for the money. It's one of corsair's weakest products and one of the only ones I consider pathetic quality. Are you trying to justfiy a PSU that is being beaten by Areocool and Inwin?
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9977127
Yes, because they're not as laughably bad as you're trying to make them out to be. I'm fairly sure others on this forum will share the same view.
https://linustechtips.com/topic/792134-500-aud-first-system/#findComment-9977148
