Hi, Guys,
I fully understand that to sync certain RGB functions on the hardware we use on our PCs, they must be of the same brand or compatible with the RGB synchronization software of the brand.
And I'm concerned that some other components, can not be synchronized because they are not of the same brand, (liquid refrigeration, fans, etc).
I use all ASUS stuff, but in mini-itx, and I see that I only have one rgb hub on the motherboard.
How do I add more led strips or fans, and synchronize everything with the software?
I recently entered the Asus Aura website and I see that there is more hardware compatible with ASUS AURA, (chassis "NZXT" for example) and I wonder, is the liquid cooling kraken compatible with Aura Sync ?, or the Hue + is it?
I also see that Cooler Master has its Master Fans pro fans, which are compatible with AURA SYNC, and they have a HUB to connect all fans in it and keep sync it all, and im wondering if this hub have sync support with led strips,  in the same hub, and synchronize it all (inside the tower) through this Cooler Master hub?
I want to have all rgb inside my computer synchronized, and also, have a led strip behind the desk.
what dou you recommend?
Remove all hardware that has RGB and put a HUE +?
https://linustechtips.com/topic/791949-rgb-sync-hub/
Just now, Abdy93 said:
-SNIP-
There is no way to sync different manufacture's RGB systems since they are manufacture specific. The only option you have is to have a complete matching system or to use a dedicated system for everything. You can add more RGB LED's if your motherboard has a RGB header and is under the max rated capacity it can handle, stuff like the NZXT Hue+ will not work with aura sync.
-Moved to Modding Section-
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9974486
I know, but, Im interested on this Cooler Master RGB Hub, and try to sync fans and leds with it.
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9974529
For fans and RGB LED's they will be simple as Cooler master makes Aura sync comaptible fans, the LED strips would be no different than getting an standard set of SMD5050 RGB LED's and wiring it to the RGB header on the motherboard. Both of those devices, the fans (hub) and the LED's would be on the same header to sync everything together.
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9974548
Thanks W-L
I found this http://www.silverstonetek.com/product.php?pid=729&area=en
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9979142
So do all RGB strips work with all RGB controllers? I've got a Phanteks Evolv, but I'd like to use the Corsair Commander Pro to control the RGB.
Sorry to ask here, but I don't want to start a whole new thread for a slightly different question. ?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9979897
As long as they are SMD 5050 series LED's yes it will work with the Aura sync or Corsair systems. The only thing is the connectors as they can vary between different manufacture's Phanteks uses a JST-SM type connector (Left) so they do make an adapter cable for it to be used as the common 4 pin connectors used with RGB LED's which will work with motherboards but Corsair uses another type (Right).
imgImage result for Corsair rgb led
http://www.phanteks.com/PH-CB_RGB4P.html
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9979920
So is there a Phanteks RGB controller and software? My mobo doesn't have an RGB header.
Mouse: EVGA X17
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9979930
No Phanteks cases have a built in manual controller to change through different lighting modes and colors nothing software based.
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9979958
I noticed that when I read through the manual. Which I only did because a sticker on the fan hub told me to.
Mouse: EVGA X17
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9980173
12 minutes ago, Abdy93 said:
What About fans?
I wan to use all my fans with RGB, but wich one?
becouse all connectors are different...
If I buy the Silverstone HUB, wich fans I need? couse I want to sync it all, fans, leds, motherboard, gpu, rams
The silverstone hub is designed for their version of the RGB fans which uses the hub to interface with the motherboard.
https://linustechtips.com/topic/791949-rgb-sync-hub/#findComment-9985625
