My first Build
Go to solution Solved by Armakar,
Don't buy that PSU, it's garbage. Get something like an Corsair RM500X or an EVGA Supernova 550. That PSU has been known to fail quite a bit.
Those fans are VERY, VERY loud. I bought them and jesus christ they they are a rocket, I replaced them with Be Quiet! pure wings 2 and Corsair AF120 Red LEDs, far, far better and not that much more expensive. Seriously, don't buy those fans.
Also, you haven't listed a CPU cooler. I assume your going with Ryzen stock cooler? If so, I'd reconsider. The 1700 is a great bargain but only because it has the potential to overclock to nearly the same performance as an 1800X - your not going to comfertably OC a 1700 very much with the stock cooler. The 1700 is a monster when you can get a big overclock on it. If you can afford it, get an AIO watercooler for $80-$100, or there are $25 coolers that give you great cooling like the Cooler Master Hyper 212.
They are the only things I think you absolutley need  to change, however there's a few other things you could change.
The SSD is okay, but there's better SSDs out there for similar prices from Samsung, HyperX Kingston and maybe Crucial.
The case is okay, but you can get some pretty great cases for not much more, take a look at the Phanteks P400S / P400S Tempered Glass for example.
Finally, the GPU is okay. There's again better brands out there for 1070's, like Asus, MSI or Zotac. I've never seen anything amazing out of KFA other then the Katana and HOF cards.
Make sure you think carefully about what you want to buy. Many people buy their first PC, cheap out on weird parts and regret it later.
Hey, guys, I wanna do, my first PC build but I'm not sure that all the parts I chose works  together
this is the parts list:
  • CPU: AMD Ryzen 7 1700
  • M.B.: Gigabyte GA-AB350-Gaming 3
  • GPU : 8GB KFA2 GeForce GTX 1070 EX OC Sniper Edition
  • Ram: 16GB G.Skill Flare X Red DDR4-2400 DIMM CL15 Dual Kit
  • Case: Cooltek TG-01 Basic
  • PSU: 550 Watt Corsair CS Series CS550M Modular 80+ Gold
  • SSD: 240 GB Sandisk plus
  • HDD: 3TB from some company (I have it at home so I don't really know)
  • fans: 4x Cooler Master SickleFlow 120 Red LED
please help
https://linustechtips.com/topic/791576-my-first-build/
PSU is trash, case is pretty poor as well. SSD is meh. RAM speed is pretty slow, especially for a Ryzen CPU. I tend to aim for an X370 board with R7 chips, but the AB350-Gaming 3 is a decent B350 board, so that wouldn't be too bad. However, why R7? Will you be utilising it properly?
What's your budget?
What exactly will you be using the system for? What games/programs
What monitor(s) will you be using with this system?
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/791576-my-first-build/#findComment-9970345
Just now, memo_9992 said:
I'm in Germany
Right - you can use this site called PCPartPicker (de.pcpartpicker.com) to pick parts with the lowest prices and check compatibility.
 For example:
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (€307.98 @ Mindfactory)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (€93.08 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  (€127.45 @ Mindfactory)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (€95.81 @ Amazon Deutschland)
Video Card: Zotac - GeForce GTX 1070 8GB AMP! Edition Video Card  (€417.02 @ Mindfactory)
Case: Cougar - MX310 ATX Mid Tower Case  (€44.90 @ Caseking)
Power Supply: XFX - TS 650W 80+ Gold Certified ATX Power Supply  (€78.04 @ Mindfactory)
Total: €1164.28
Generated by PCPartPicker 2017-06-11 02:20 CEST+0200
idk
https://linustechtips.com/topic/791576-my-first-build/#findComment-9970348
What's your budget?
I have the samsung c24fg70fqu and my budget is about 1200€
I program and game and sometimes stream
https://linustechtips.com/topic/791576-my-first-build/#findComment-9970392
 For example:
Total: €1164.28
I hate PCPartPicker because the prices are not as they are on the websites
https://linustechtips.com/topic/791576-my-first-build/#findComment-9970398
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (€315.97 @ Amazon Deutschland)
Motherboard: ASRock - X370 Killer SLI ATX AM4 Motherboard  (€162.14 @ Amazon Deutschland)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (€140.99 @ Amazon Deutschland)
Storage: ADATA - Premier SP550 240GB 2.5" Solid State Drive  (€81.03 @ Amazon Deutschland)
Video Card: Asus - GeForce GTX 1070 8GB Dual Series Video Card  (€405.00 @ Amazon Deutschland)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  (€85.67 @ Amazon Deutschland)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (€71.89 @ Amazon Deutschland)
Total: €1262.69
A little over budget but you could easily get an R5 1600, which would still be perfectly adequate and save 100 euros. Or, get a cheaper motherboard and save about 50 euros;
https://de.pcpartpicker.com/product/fPDzK8/asus-prime-b350-plus-atx-am4-motherboard-prime-b350-plus
The X370 motherboard gives you SLI support though, and is just a better motherboard.
If you do get the R5 and/or cheaper motherboard, you could get this better PSU instead;
https://de.pcpartpicker.com/product/9G7wrH/xfx-power-supply-p1650bbefx
and alternative RAM;
https://de.pcpartpicker.com/product/T9Gj4D/gskill-memory-f43200c16d16gvk
The prices on PCPP for all these is pretty accurate.
https://linustechtips.com/topic/791576-my-first-build/#findComment-9970508
Total: €1262.69
Amazon is pretty expensive and that's why I don't even use it but Ty I will consider your hint
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971622
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971718
I'm was considering the AIO but as an upgrade and for the fans I'll see what I can find
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971731
Fair enough.
For the fans, like I said, you'll regret buying them. The Corsair AF120's look nicer, are built better, are far quiter and even have a brighter LED (and come with full length screws) and are $3 more expensive per fan.
The Be Quiet! Pure Wings 2 are the same price per fan, far, far quiter, far better build quality and.. their german, german people make Audi's and Audi's are nice.
Good luck shopping.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971742
Just now, Armakar said:
Fair enough.
Good luck shopping.
What PSUs can I buy for about 70€?
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971747
RM550X and EVGA Supernova's  should be around that price for gold rated PSUs.
If not, the supernova G2's defnitley will be around that price, as will the Corsair CX550M, which is also pretty good.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/791576-my-first-build/#findComment-9971774
