Charging mobile phone
Go to solution Solved by themctipers,
Just now, ringo said:
How much faster? Big difference?
i think from 500ma to 2a
huge difference, 4x faster
USB 3.1 type A should charge it faster (idk what 3.1 looks like, I assume it's the same type A connector, If it's some different one and you need an adapter just plug it into USB 3)
make sure fast charging is enabled on your motherboard (it's a USB 3 spec IIRC for more power output to charge devices)
or just plug it into a wall wart
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/791339-charging-mobile-phone/#findComment-9967954
https://linustechtips.com/topic/791339-charging-mobile-phone/#findComment-9968325
https://linustechtips.com/topic/791339-charging-mobile-phone/#findComment-9968328
