I was just wondering if anyone knew what model of xeon is in the new iMac. The apple website as you know give a crap load of detailed information.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/790142-imac-pro-xeon/
They didn't give any information about it, so no one knows.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954281
typical Apple. Always giving useless information!
My Stuff n' Things
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954287
It's not even available for pre-order. That info generally gets released then.
PSU Tier List | CoC
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954291
this is from the macbook air. no model number
My Stuff n' Things
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954299
You can easily figure out what CPU is being used by the specs.
PSU Tier List | CoC
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954414
yes but why cant they just say it. It's 4-5 f***ing characters. didnt know they were that lazy
My Stuff n' Things
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954432
if I could create a single law. it would be a requirement to identify in detail components anywhere they are mentioned.
My Stuff n' Things
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9954447
16 hours ago, TheCherryKing said:
The 18-Core Xeon is probably an E5-2699v4. The new top of the line Xeon has 28 cores.
actually the 2699 is a 22 core. I played with the filters on the intel products page and found a list of possible cpus.
My Stuff n' Things
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9963119
I am 99% sure its not gonna be one of those. Why? Apple is either gonna use the server/workstation equivalent of x99 (unlikely) or x299 (likely), and the Xeon E7 are meant for the quad socket systems.
Given that they are using 8-18 cores, which is in line with the new i7/i9 line, and the Xeon e5 16** line is typically in line with those and is meant for single socket systems I wouldn't be surprised if we see them using the latest version of those (v5 I suppose).
The e5 26** doesn't make sense to use given that those are dual socket, which wouldn't be useful at all given that the iMac Pro is a single socket system.
Xeon e5649@4.4 GHz on Asus Rampage II Extreme or Gigabyte x58a-OC (whatever I feel like to set up at a time) , 6x4 GB Kingston HyperX 1600, Gainward GTX 670 Phantom, Samsung 840 Evo 240 GB, BeQuiet L8 530W
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9964026
My bad. I meant the 2699v3. The Mac Pro used an E5 26** processor even though it only had one socket. Besides Intel changed their naming scheme again! The new Xeons no longer are called E3, E5, or E7.
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9964998
45 minutes ago, lilbman said:
Doesn't really matter LOL, it's going to thermal throttle to hell and back anyway when you try to do anything demanding.
possibly, but we don't know that yet and we won't know that until units are available in December-ish.
PSU Tier List | CoC
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9965212
Unless it is watercooled, I honestly doubt that you could keep a 120W TDP processor and a potentially 150W TDP graphics card cool under load in one of those things.  It just doesn't look like it could really keep the internals running under full load without thermal throttling, and as we all know, Apple doesn't really place a priority on keeping their products cool..
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9965529
If the fans run at 50,000 RPM, then it would be cool. The fact is you really can't say that it will throttle. There's a good chance it will, but it's not guaranteed nor can we say to what extent it will throttle.
PSU Tier List | CoC
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9965539
I really can't say it will, correct.  I guess we will find out this December.
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9965685
I just realised they never went with more than 8 cores for the 16** CPUs, so I suppose that is the reason why they used the dual-capable 26**. We'll see what they end up using through either leaks or in December.
For thermal throttling: while we have seen many Macs throttle before, the trashcan didn't, while many expected it to. Lets wait for the release and tests to say that if it does. The 2012 iMac had a 95W 3770 and a 100W 675mx in its top configuration, so maybe the new cooling setup can handle an additional 70W.
https://linustechtips.com/topic/790142-imac-pro-xeon/#findComment-9967238
