Hi all,
I have my PC plugged into th socket in my room upstairs. For a long time it would start buzzing randomly and I didn't know why. It turns out that if you turn on the lights in the living room then my PSU will start to buzz (the lights always buzz). I'm thinking it's destabilising the voltage in the circuit? Anyone know why this is happening? And more importantly any way to fix it?
That's an F in the profile pic
https://linustechtips.com/topic/789117-strange-psu-issue/
It's most likely fluctuations in the mains network.
I'd recommend a voltage stabilizer or a UPS (which should have built in protection).
Same thing happens to my mom's PC and monitor. So far no PCs were harmed, but one of the monitors she had crapped itself. Could be unrelated, though
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9941823
Doesn't sound unsafe, but not unreasonable to have an electrician look at the home wiring.  Might even be advisable to have an Uninterruptible Power Supply or Battery Backup, as most are isolated AC units and properly filter the voltage to prevent any potential issues with your system.  Again, doesn't sound like a serious issue, but if it gets on your nerves, the UPS should alleviate it.
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9942183
I agree with some of the others.  Doesn't sound like PSU problem, but more of a house wiring problem.
I would suggest a UPS and a high end surge protector.
And maybe seeing if those lights and your PSU are on the same circuit in the home's main load center box -- may be outside or inside home.  If so, you may wanna change your PSU plug in spot in your home and get onto a whole other circuit/breaker -- different plug receptacle.
CPU:  Intel Core i7 7700K OCed to 5GHz.
Motherboard:  Asus ROG STRIX RGB GAMING Z270E.
RAM:  G.Skill TridentZ RGB Series 32GB DDR4 3200MHz.
GPU:  EVGA GeForce GTX 780 Ti Dual Classified w/ EVGA ACX Cooler (Highly Overclocked on LN2 BIOS).
Case:  Corsair Graphite Series 780T Full Tower -- Black.
Storage:  2x Samsung 960 2TB PCIe NVMe M.2 SSDs (RAID 0), Samsung 850 Pro 512GB 2.5" SATA III Internal SSD, Samsung 840 EVO 250GB 2.5" SATA III Internal SSD, Corsair Voyager GTX 256GB USB 3.0 Rear Flash Drive, Samsung MUF-128DA2/WW USB Type-C 3.1 128GB Rear Flash Drive, (In-Home Router Backup) -- WD 4TB Black My Passport Portable External USB 3.0 HDD.
PSU:  Corsair AX860 Platinum Edition; Fully Modular.
Cooling:   Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler w/ 4x Noctua SSO2 Bearing NF-A14 iPPC-2000 PWM Fans in Push/Pull Exhaust Configuration; 5x Corsair ML120 Pro LED Blue 120mm Premium Magnetic Levitation Cooling Case Intake Fans; and 1x Corsair ML140 Pro LED Blue 140mm Premium Magnetic Levitation Rear Exhaust Fan.
Interior Lighting:  2x Corsair Lighting Node Pros -- (Bright White Interior Illumination).
Keyboard:  Tt eSPORTS MEKA G1 Illuminated Gaming Keyboard w/ Cherry MX Black Keys.
Mouse:  Razer DeathAdder Chroma - Multi-Color Ergonomic RGB Gaming Mouse (2015 Model).
Sound:  Integrated Sound -- Razer Kraken Pro Headphones w/ Mic -- BOSE Companion 2 Series III Multimedia Speaker System.
Monitors:  3x (HP 2511x) 25-Inch LED Monitor--Black.
OS:  Windows 10 Professional.
Wireless Router:  NETGEAR Nighthawk AC1900 Dual Band WiFi Gigabit Router (R7000).
Modem:  NETGEAR CM600 24X8 Cable Modem DOCSIS 3.0 Max Download Speeds of 960Mbps -- (ISP-Spectrum).
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9942468
I really don't want to move my PC since it's in my room and I spent a bunch of time setting up speakers and such and don't have another room.
Thanks @Iggledude, @Doramius, @CUDA_Cores, @stefanDB, @revsilverspine
So if I wanted to clean the power I would use a UPS obviously, but one that will be near the capacity of my PSU is pretty expensive for my small budget. I saw some power cleaners a while ago made for audiophile systems that don't cost so much. Will they work?
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9942785
What is the wattage of your PSU?  I can understand trying to keep the cost down, but UPS usually aren't too expensive.  Considering a 1200VA Voltage Regulator is about $50 USD, and a 1200VA UPS is around $150 USD.  I feel the extra cost is worth it, but the additional $100 can be tight for anyone.
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9948832
It's a 700w (VP-700P) which I'm not using to near its full capacity but I would prefer to have the headroom. Do you know if the power cleaners I mentioned earlier would work?
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9948881
They do filter the voltage to keep it clean and it "should" reduce or remove the buzz.  However, it is not an independently isolated AC circuit with filter as a UPS would be.  It's just an inline filter of the voltage.  Being that it is supposed to be clean voltage, there should not be a buzz.
Here's a link to a voltage regulator, though: https://www.amazon.com/APC-LE1200-Automatic-Voltage-Regulator/dp/B00009RA60
https://linustechtips.com/topic/789117-strange-psu-issue/#findComment-9948931
