Hey guys,
As in the title I'm getting an Error code 61 on the workstation I'm putting together.
Specs:
2x Intel Zeon E5-2630 v4
Asus Z10PE-D16
2x Crucial EUDIMM DDR4 16Gb (CT16G4WFD8213)
Sapphire HD7770
EVGA 750GQ
Thoughts? Ideas? Any help?
My PC
Starry Night:
CPU: Intel Core i7 7700k | Motherboard: MSI Z270 SLI Plus | RAM: 32 GB GSkill DDR4 2133 MHz | GPU: EVGA GeForce GTX 1080 Ti SC Black Edition | Case: NZXT H440 | Storage: Crucial MX300 M.2 | PSU: Corsair RMx 750 | Display(s): Dell S2417DG 2560X1440, Dual AOC 1920X1080 (E2426WD, I2421VWH) | Cooling: NXZT Kraken x61 | Keyboard: Logitech K350 | Mouse: Logitech M500 | Sound: Logitech Z506 5.1 Channel and Phillips SHP9500 | Operating System: Windows 10
Tyrosine:
CPU: Intel Core 2 Duo E8400 "Wolfdale"   Motherboard: Gigabyte P35-DS3L   RAM: 4 GB DDR2 400 MHz   GPU Power Color R9 380 4GB   Case: Antec with Blue light and over 9000 fans, and 9000 lbs   Storage: Samsung Evo 850 + 600 GB HDD   PSU: Corsair VX 550 W   Display(s): Dual AOC 1920X1080 (E2426WD, I2421VWH)   Cooling: Did I mention the case?   Keyboard: Logitech K350   Mouse: Logitech M500   Sound: Logitech Z506 5.1 Channel and Phillips SHP9500  Operating System: Windows 7 on Desktop, Ubuntu 14.04 on Laptop and everything else
Kids, do drugs, the science way! Note:
I am involved in computational medicinal chemistry research and am interested in pharmaceuticals as a researcher, in no way do I endorse the taking of the drugs. Never.
https://linustechtips.com/topic/788059-q-code-61-memory-error-workstation-build/
On the motherboard and/or box there should be a sticker indicating the BIOS version, what BIOS version did the motherboard come installed with?
What memory slots have you got the RAM modules installed into?
What storage device(s) are you using?
Didn't come with a manual, and cant seem to fund any stickers, but it says Rev 1.04 on the board. I have the sticks i  the A1 and E1 slots, and I have a Crucial MX100 and a AD Black.
My PC
Starry Night:
Tyrosine:
There should be a sticker with the serial number and BIOS version on it. It could be on the front or back of the motherboard, or on the side of the 24 pin power socket.
There is a possibility that the motherboard has an older BIOS version compatible with only the V3 CPUs, and requires a BIOS update to support the V4 processors.
Closest thing I found to a version number is 3104, the last 4 digits on a sticker at the bottom of the board.
My PC
Starry Night:
Tyrosine:
That should be fine then, BIOS revision 3104 added compatibility for those processors.
Have you tried using one CPU and one RAM stick at a time?
Nope. I'll give that a go now.
My PC
Starry Night:
Tyrosine:
Tried CPU 1 with one DIMM, no dice.
My PC
Starry Night:
Tyrosine:
My PC
Starry Night:
Tyrosine:
