Hey guys, my friend's H100i v2 seems not to cool his CPU. He can hear the coolant pumping and the fans are running. Any clues?
Specs:
i7-6700
ASUS ROG STRIX 1080Ti
ASUS Maximus IX Hero
EVGA 600B
2TB HDD
120GB Samsung SSD
eJwVzEEOhCAMQNG7cACKlM4Yb0OQIBOZElpXxrury_8W_zTH2M1iNtUuC8BaJfFYrSiPWLItzGXPsVexiRtE1Zi2lv8q4OfJk0Oi6fshfAIBvcNAsyPy-HAIDmp7N79ezHUDvGYhsw.jpg
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/788017-h100i-v2-problem/
this might sound like a stupid question but did you check the thermal paste?
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9928241
Yes. it's there.
Skyggeis Specs:
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9928260
4 minutes ago, ImNotThere said:
Idle temps, load temps plz
77C, didn't bother with load.
Skyggeis Specs:
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9928264
32 minutes ago, ImNotThere said:
Huh, um, check thermal paste, make sure its mounted properly, take it off and reapply thermal paste, check the plastic part isnt on the bottom of the block
Redid thermal paste, no luck.
Skyggeis Specs:
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9928393
Specs:
i7-6700
EVGA 600B
2TB HDD
120GB Samsung SSD
Also, is it a case of as soon as you turn on or is it gradual?
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9929886
He's getting it RMA'd. And it's not the CPU, it's fine with his old Dark Rock 3. And it's as soon as it turns on. Gradual if going from room temp to 70º+ is gradual haha.
Skyggeis Specs:
https://linustechtips.com/topic/788017-h100i-v2-problem/#findComment-9962935
