Audio Help
Go to solution Solved by Tsuki,
holy crap, im literally retarded.
just looked back at the tag, the 0 in 80, was actually the O in Ohms.
its '8OHMS', not '80 HMS'
problem solved, itll work fine
So, I know a ton about computers, and basically nothing about audio.
Ive got a pair of large passive tower speakers at home, that according to the tag on them, are rated at 80 Ohm impedance and a max of 180 Watts.
my plan was to use a raspberry pi with a JustBoom Amp Hat on it to power the speakers and act as a media player (using Volumio).
the Amp Hat ouputs 2x55W which should be enough to get the speakers plenty loud enough, but the amp is only rated for 4 or 8 Ohms.
Is it actually going to work, or will everything just explode?
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/787231-audio-help/
22 minutes ago, SSL said:
What's the model of speaker?
KenWood JL-975AV
i cant find any information about them online however, the tag on them has the following information:
4way 5 speaker system
impedance 80OHMS
max input power 180W
frequency range 30Hz~20kHz
|Specs in profile|
https://linustechtips.com/topic/787231-audio-help/#findComment-9918759
|Specs in profile|
https://linustechtips.com/topic/787231-audio-help/#findComment-9923597
