I was wondering. Is it better to have your fans blow out the back or blow out the front or is it situational? The reason I ask this is because I building now my 3rd comp but its place will be with its rear against a wall. So I was wondering if it'd be ok to make the fans push forward so it doesn't suffocate.
https://linustechtips.com/topic/786940-front-or-rear-cooling/
It's better in the back. The front fans usually have a dust filter and they are placed on the bottom (because hot air goes up). The back fans are placed higher. Do you have any top fan slots? Those are the best.
PC: Case: Cooler Master CM690 II - PSU: Cooler Master G650M - RAM: Transcend 4x 8Gb DDR3 1333Mhz - MoBo: Gigabyte Z87x-D3H - CPU: i5 4670K @ 4.5Ghz - GPU: MSI GTX1060 ARMOR OC - Hard disks: 4x 500Gb Seagate enterprise in RAID 0 - SSD: Crucial M4 128Gb
Phone: Samsung Galaxy S6
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9915483
yes I would have 1 rear top. I guess my thought was it wouldn't get enough air flow being close to the wall
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9915619
1 sucking in the front and 1 blowing on the top should be allright. What are your specs?
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9915812
msi gtx 1060 6gb
2x4gb ram ddr4 2400 corsair vengance
and ryzen 1500x 3.5
corsair rm 550w 80+gold
msi proseries b350 ryzen micro atx mobo
1tb wd black
250gb ssd Samsung evo
fractal core 1500 micro atx case
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9915950
Change the back fan to the top (blowing out). Leave the front fan in (sucking). If you have another fan then place it next to the top one (also blowing out). Also rotate your CPU Cooler (if it isnt a stock cooler) so it points upwards (blows air to the top).
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9916154
what if i added a fan to the top and had that blowing up what that be ok to?
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9916159
I made a picture for you. I numbered the positions in order. So first fan would be on place 1, second on 2, etc.
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9916173
Front fans bring cool air for GPU. Mainly, and some to CPU ofc. But seeing as you got that sorted already, nvm.
How close to wall would this have been? My case is about 10cm and it doesn't cause anything. Except wall being bit hot.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9920703
it's prolly about the same. I guess i'm just still not fully aware how cooling works so I figured. Better to be safe then sorry xD
https://linustechtips.com/topic/786940-front-or-rear-cooling/#findComment-9922877
