3 hours ago, Darkshadowhaxor said:
I've tried plugging the ADSL into the wan port directly, it clicks in but the router doesn't receive any connection
Could you use the isp box and connect your own router for the network?
Main PC: Ryzen 7 7800X3D | 32GB GSkill 6000 MT/s | B650E TUF Gaming WIFI | 2TB Samsung 990 Pro | 2TB Samsung 990 EVO | Gigabyte OC RTX 4080 Super | Corsair 5000D Airflow |                  1000w Seasonic GX | Windows 11 Pro
Laptop 1: Macbook Pro 14" M3 Pro | MacOS 15.x
Laptop 2: Razer Blade 15" Base 2021 | Windows 11/Pop! OS 22.04
Servers 1-3: Super Micro 813MFTQ-441CB | Xeon E5-2650 v4 | 128GB of ECC DDR4-2133 | 2x 250GB Micron 5200 MAX | OS: Proxmox 8.x |
Server 4: Dell DP4400 (R740xd) | 2x Xeon Silver 4114 | 64GB of ECC DDR4-2400 | 2x Crucial MX500 (Boot) | 2x Seagate Exos 18TB, 1x WD White Label 18TB, 5x 14TB Seagate Exos,                          2x Samsung 870 EVO 500GB (L2ARC), 2x Samsung 863a 960GB (S Log)
https://linustechtips.com/topic/786238-router-help/#findComment-9906820
Just now, BubblyCharizard said:
most ADSL routers can be put into bridge mode
what model is it?
I have the crappy ISP router as a form of modem. into a decent router. Problem is I don't want to have the crappy isp router as a modem. I Just want a direct connection into my decent router
https://linustechtips.com/topic/786238-router-help/#findComment-9906981
Just now, Darkshadowhaxor said:
the tplink doesn't support ADSL input, you will still need to use an ADSL modem
your Fibre optic internet isn't delivered over fibre, but copper from the Telecom companies local node
Up here, Bell advertises DSL as FIBE, and telus advertises their DSL as OPTIK
if we know what model you are using, then we might be able to help If your connection is bonded, however, you may be forced to use the ISP provided modem
https://linustechtips.com/topic/786238-router-help/#findComment-9906995
I doubt its bonded. I live in the UK and I use Plusnet / BT / Openreach
https://linustechtips.com/topic/786238-router-help/#findComment-9907000
The max I can, 76/18
definitely not ADSL....thats VDSL
I'd recommend something like the smartrg 501
IT should do the trick and is just a modem, I'm not sure if BT is using PPPoE or just regular DHCP for their VDSL connections, so it might be plug and play, or you may have to call in to get login credentials
https://linustechtips.com/topic/786238-router-help/#findComment-9907031
Oh. Thanks for enlightening me on my connection format and the suggestion. I shall look at it shortly! Thanks
https://linustechtips.com/topic/786238-router-help/#findComment-9907040
Would this work?
https://linustechtips.com/topic/786238-router-help/#findComment-9907042
