This is the notebook I have - http://www.asus.com/Notebooks_Ultrabooks/K53E/
Recently I've been working with an extensive set in a DAW and it has been sucking the CPU power entirely. The program is 64 bit and I have tweaked it to work with the four threads and within the program started using it to save CPU power. Even with this, my CPU just doesn't have the power I need. It has a i5-2410M, like the lowest tier of the mobile i5 range, and it is sandy bridge. The chipset in the laptop is an HM65. My options at this point are to buy a new laptop or replace the CPU with one that has more power, which seems lie it would be more cost effective.
Three questions -
1. Is it possible to replace the CPU in this laptop model?
2. What is the best CPU (preferrably i7) I could replace with this socket and chipset?
3. Where can I buy a laptop CPU?
Thanks for any help.
CPU - Intel Core i7 3770K @ 4.60GHz 1.264v | RAM - Corsair Dominator Platinum 16.0GB (2x8GB) | Motherboard - ASUS P8Z77 WS | Graphics - EVGA NVIDIA GeForce GTX 960 | Storage -  120 GB Samsung 840 EVO | PSU - Corsair RM650 | Case - Corsair 550D
https://linustechtips.com/topic/7859-replace-a-cpu/
I just opened it up... It does have a removable CPU. The socket has a black flat head key that releases the CPU out of the socket. Now the question really is compatibility with the chipset. I just don't know where do look to research this kind of thing.
https://linustechtips.com/topic/7859-replace-a-cpu/#findComment-88173
Looking at the Asus Spec Page of that laptop, you can place in a Intel Core i7 2670QM or a 2630QM.
Id probably just go and get a new laptop if I had the money though... :)
https://linustechtips.com/topic/7859-replace-a-cpu/#findComment-88417
