11 minutes ago, Tomlintm said:
I just bought a a nee power color rx580 8gb golden sample card and for some reason i both oc and silent i get memory errors at 2000 mhz which is stock memory speeds and idk why any help would be great
What are your specs ?
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9899884
CPU-AMD FX-8350
Motherboard-ASRock Fatal1ty 990FX Killer
RAM-G.SKILL Sniper Series 16GB (4x4GB) DDR3-1600
GPU-Powercolor RX580 8gb Golden Sample
Case-CoolerMaster MasterCase Maker 5
Storage-Samsung 120GB SSD 840 Series,WDC WD1002FAEX-00Z3A0
PSU-EVGA SuperNOVA 850 P2, 80+ PLATINUM 850W
Display(s)-3x AOC 2269WM 22in
Cooling-Cooler Master Hyper 212 EVO/with 120 mm
Keyboard-Redragon ASURA K501 USB Gaming Keyboard
Mouse-Redragon M601 CEN
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9899893
Just now, Tomlintm said:
CPU-AMD FX-8350
I think your CPU is bottlenecking your GPU
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9899895
2 minutes ago, Tomlintm said:
ya i kinda figured but im having vram memory errors and i didnt think a bottle neck would cause vram to error up like that
I didn't think it would cause issues like that either.
I'm not familiar with a sample card. What's that?
Have you tried manual OC?
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9899914
from what powercolor said all it is a binned gpu like the kingpin its a marketing gimick lol
it comes factory overclocked with 2 settings switch on the pcb oc which does 1425 and silent which does 1411
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9899928
What do you mean you have errors? Are your games not running well?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9900058
8 minutes ago, Tomlintm said:
gpu memory errors im not sure how it works but hwinfo64 detects them and i no there not good for a gpu
If you're games are running without crashing, it doesn't matter
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9900101
34 minutes ago, Tomlintm said:
so your saying even tho errors are bad it doesnt matter as long as it not crashing the game to just ignore it
Memory errors are blown out of proportion. It's fine.
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9900270
1 minute ago, Tomlintm said:
what do you mean how is it blown out of proportion
Are your games crashing? No? Blown out of proportion.
https://linustechtips.com/topic/785579-need-help-with-new-rx580/#findComment-9900281
