FX-8320 No-post
Solved by KerbalPhysicist,
On 5/27/2017 at 11:36 PM, MysticalRainXIV said:You pretty much covered all you bases already so theres nothing else I could think of that could help alleviate the problem. I hope all goes well in your endeavors, and If you manage to fix it please let me know, I'd be curious as to what made it tick again.
Welp, basically I just had to replace the mobo, I got as close to the same model as possible, so I didnt even have to reactivate windows. And since its newer I've got USB-C now to boot! but no thunderbolt, because its still an old AMD machine...
