Microphone doesn't work. HELP ASAP
So on my Toshiba Satellite S55-B5155 Microphone and webcam stopped working. I tried reinstalling the drivers.Didn't help. I formated the whole hard drive,installed fresh windows 8.1 after I downloaded audio drivers from Toshiba's website, installed no results. In device manager it recognizes my microphone.With webcam it's different story it doesn't even appear in device manager. Speakers are working properly. Maybe it is a hardware issue? but if so why speakers are working if the soundcard is okay?
https://linustechtips.com/topic/784891-microphone-doesnt-work-help-asap/
Use Windows 10 and see if it works. Your 8.1 key should work for win10 just fine, and it's a pretty good OS.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
If some devices aren't appearing in the device manager then it's not related to the OS.
Also, the microphone isn't the sound card, it's something that is PLUGGED into the sound card.
So it's totally possible that it's a problem with one of the ribbon cable inside the laptop (I would say it's probably 99% the reason for this "all of a sudden" problem).
If you need help with your forum account, please use the Forum Support form !
