hey to whoever is here, i currently have an rx480 as well as a samsung 24" CF390 Curved LED Monitor, i want to get into dual screen with eyefinity, but... for some reason all the retailers in my country doesnt sell it anymore, so, i have some questions:
1. what other monitors can i use, can i get a 27" display?
2. can i use a flat monitor? will it be comfertable in any way?
3. can my graphics card even run dual monitors without chocking?
thanks alot
https://linustechtips.com/topic/784761-eyefinity-help/
Wouldn't recommend dual monitors for eyefinity... the separation between the two monitors will be right in the center of the image, which is where important things tend to be happening ingame.
https://linustechtips.com/topic/784761-eyefinity-help/#findComment-9891162
