Been searching up whether my temps were okay after overclocking my Kaby lake wanted, I wanted to triple check if these are okay.
Overclocked it to 5.0ghz
On idle hovers between 34-47c
and I did a stress test using Intel burn stressed level at very high - I'm hovering around 64-76c (once peaked at 82 that was on one core though the rest of the cores were fine)
https://linustechtips.com/topic/783588-overclocked-cpu-temps-question/
What CPU and cooler?
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
Useless info, idle is irrelevant outside of 70+ (in which case, it means bad cooler mount).
Useless again, without any context on cooler, voltage and clocks. Temps are within a very confortable range, however.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Which CPU is it? BTW, I would recommend AIDA64 if you want to see how high your temps will go :D
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Probably a 7700k, as that's the only unlocked Kaby Sku (that makes sense).
Just now, cookiejarmonsta said:
Whoops forgot to add that in im using the corsair liquid cooling h100i v2
Those are really solid temps at that frequency. What voltages?
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
Temps seem to good to be true... Use AIDA64 or Prime95 to stress test your CPU and re-check your temps...
I just download prime95 is there a way to properly stress test the CPU, seems to complex for me oppose to my original one.
I think I got it right, for the torture test I used the first option which is small FFTS. I ran it for a solid 10 mins and these were my results. I've noticed only one core went into yellow zone as you can see in the image. Though I dont understand how core 2 didnt go to 100% load.
Oh I also noticed my pump was making noise every now and there which I've never heard before when stressing on the other program i was using lol, i did further search, and moving the pumped seemed to fix it temporarily.
Try AIDA64 and enable CPU, FPU and cache stress test :D
41 minutes ago, cookiejarmonsta said:
BTW, your voltage is way too high. Why did you set it at 1.42V?
12 hours ago, cookiejarmonsta said:
Oh I fixed it. I downloaded Aida64 and I ran the test for an hour as ill be heading to work right now. Does this seem, right?
Yep, seems very good to me :D
