8 minutes ago, ItsJoshuaS said:
I want to connect my PS4 Pro to my monitor.
I have a vgu to HDMI.
I have power points
what else do do I need to connect my PS4 to my monitor
also my monitor is really shit it can only run 1080p
it only has vgu and power
i believe thats it your good to go
https://linustechtips.com/topic/783517-ps4-pro-stuff/#findComment-9875880
23 minutes ago, p.klokgieter said:
Nothing you really need. Just connect it lol.
Is it possible you know the wifi lan cable, when the cable
reseaches my ps4 can i add a thing which doubles it?
for example i plug something in the end of the wifi cable which basically
doubles it, making to connect to my tv aswell as my ps4.
My PC Currently Is The P2-1320a.
https://linustechtips.com/topic/783517-ps4-pro-stuff/#findComment-9875938
nope.
https://linustechtips.com/topic/783517-ps4-pro-stuff/#findComment-9875943
8 minutes ago, p.klokgieter said:
I'm not quite following you. Why would you want to connect is to both your PC and TV? and as @Samson_ST said, why would you need LAN?
Because remote play is laggy and i need better wifi
https://linustechtips.com/topic/783517-ps4-pro-stuff/#findComment-9875982
