I have a gtx 1070 and I want my games to run faster than 60fps because I have a 144hz monitor but not at 144hz because my graphics card get s really hot when I turn on v-sync. On War Thunder, it just sits at 60 fps always even though the GPU usage is 30-35% But I want it to be more like 90fps, How can I tell it to do that?
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/
1 minute ago, AdinAck said:
I did and it was exactly 144fps
should be able to limit fps in the settings for the card be it afterburner of asus equivalent depending on manufacturer
  • CPU
    i7 6700k overclocked to 4.7 GHZ @1.38v
  • Motherboard
    ASUS ROG Maximus VIII Hero Alpha
  • RAM
    32GB Gskill Ripjaws @3200mhz
  • GPU
    ASUS ROG Geforce 980
  • Case
    CoolerMaster HAF X
  • Storage
    500 GB SSD and 12TB mechanical HDD some soon to be split to NAS
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874558
1 minute ago, nerdslayer1 said:
whats the problem?
too much framerate over heats his card
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    CoolerMaster HAF X
  • Storage
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874562
Just now, AdinAck said:
when v-sync is on, my graphics card fan is really loud which I don't like, I would prefer the game to work at 90fps for less of a load on my GPU and being quieter while still being a pretty good performance.
what is your full system spec?
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874564
refer to above post about framerate limiting.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    CoolerMaster HAF X
  • Storage
  • PSU
    EVGA 1000 G1
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874585
i did configure the fan curve, it is loud, I dont want to overwork my grpahics card at 144hz but I want it to be higher than 60
what? you are not overworking anything, graphic cards are designed for that, long as you stay under 85C you should be fine.
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874587
But it's loud, that's what I'm saying. the fan is at 100% thus very loud which is my problem I have explained this many times, It is -->loud<--
The noise is the problem
use the fan curve, what case do you have, it sounds like you have crappy cooling, a gtx 1070 should not go 100% fan speed at 35% gpu utilization.
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874611
My case is wood
You obviuosly do not understand the situation, I will explain again: with v-sync on(144fps) 75% utilization or higher but loud fan<--problem. v-sync off my Gpu goes to 60fps which is too low for me but the utilization is about 35% I want the fps to be 90fps not 60(too slow) not 144(too loud) get it??
https://linustechtips.com/topic/783404-low-gpu-usage-and-fps/#findComment-9874628
