i5 3570k
Gtx 960 and a intergrated GPU#
8GB ram
i tried at the satrt of the day to reinstall windows using the setting in win 10 settings menu  but then the K/M wouldnt work so after 2 hours of truoble shooting ive tried just reinsatlling windows using the meaid creation tool on a laptop onto a Usb but now it wont post now matter what
-Ive tried moveing the ram
-ive tried switching PSU
-ive treied Uing 960 and the intel gpu each
Surgestions?
https://linustechtips.com/topic/782243-help-my-pc-wont-post/
3 minutes ago, jjjackkiller11 said:
i5 3570k
8GB ram
Surgestions?
What mobo?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/782243-help-my-pc-wont-post/#findComment-9861803
Maybe ask the person at the post office to recommend  some sort of better packaging for it.
Anyways you should try one ram stick only in the first primary slot (so the second slot from the cpu normally ) and removing the gpu all together and also resetting the bios to default settings
https://linustechtips.com/topic/782243-help-my-pc-wont-post/#findComment-9861836
