Hello all,
Building a compact form factor for my wife, just want to hear everyone's opinions. I am right at the budget she wants to spend on it, ideally if we can drop it down some, I am all for it to please her. I am shopping newegg only, so keep that in mind. I am up for changing whatever needs to change to make the best bang for buck. Keep in mind, I do want to keep the ssd, hdd, the additional fans, and the case. Here is the breakdown of the build thus far. Thanks in advance. I know Ryzen is out there, I just have been using intel for so long, hard to break me back to AMD, but not opposed.
Qty. Product Description Savings Total Price
1 RAIJINTEK STYX Classic, an Alu Micro-ATX case, Compatible with regular ATX Power Supply, Max. 280mm VGA Card, 180mm CPU Cooler, 240mm Radiator Cooling On Top, a Drive Bay For Slim DVD On Side - White RAIJINTEK STYX Classic, an Alu Micro-ATX case, Compatible with regular ATX Power Supply, Max. 280mm VGA Card, 180mm CPU Cooler, 240mm Radiator Cooling On Top, a Drive Bay For Slim DVD On Side - White
Color: White Type: MicroATX Desktop Series: STYX Side Window: No
Item #: 9SIA66Z3TV7327
Sold by RAIJINTEK CO., Ltd. What's this?
-$19.91  Instant $104.90
$84.99
1 WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
Item #: N82E16822236339
Return Policy: Standard Return Policy
-$20.00  Instant $69.99
$49.99
1 ASUS ROG GeForce GTX 1050 Ti STRIX-GTX1050TI-O4G-GAMING 4GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card ASUS ROG GeForce GTX 1050 Ti STRIX-GTX1050TI-O4G-GAMING 4GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
Item #: N82E16814126171
Return Policy: Replacement Only Return Policy
$10.00 Mail-in Rebate Card $164.99
1 CORSAIR CS-M Series CS650M 650W 80 PLUS GOLD Active PFC Haswell Ready ATX12V & EPS12V Modular Power Supply CORSAIR CS-M Series CS650M 650W 80 PLUS GOLD Active PFC Haswell Ready ATX12V & EPS12V Modular Power Supply
Item #: N82E16817139060
$20.00 Mail-in Rebate Card $79.99
1 G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Platform Desktop Memory Model F4-3000C15D-16GTZ G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Platform Desktop Memory Model F4-3000C15D-16GTZ
Item #: N82E16820231911
  $135.99
1 ASUS ROG MAXIMUS VIII GENE LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 Micro ATX Intel Gaming Motherboard ASUS ROG MAXIMUS VIII GENE LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 Micro ATX Intel Gaming Motherboard
Item #: N82E16813132569
-$40.00  Instant
$35.00 Mail-in Rebate Card
$229.99
$189.99
1 Intel Core i5-7600 Kaby Lake Quad-Core 3.5 GHz LGA 1151 65W BX80677I57600 Desktop Processor Intel Core i5-7600 Kaby Lake Quad-Core 3.5 GHz LGA 1151 65W BX80677I57600 Desktop Processor
Item #: N82E16819117729
  $229.99
2 Noctua NF-F12 PWM 120mm Case Fan Noctua NF-F12 PWM 120mm Case Fan
Item #: N82E16835608026
  $37.90
1 Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
Item #: N82E16835103099
-$10.00  Instant $34.99
$24.99
1 SAMSUNG 850 EVO 2.5 SAMSUNG 850 EVO 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E250B/AM
Item #: N82E16820147372
-$2.00  Instant $109.99
$107.99
Total = $1106.81
https://linustechtips.com/topic/781811-first-micro-build/
the build's a big mess. give me abit of time, i'll send you a pcpp link
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856781
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($217.89 @ OutletPC)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($78.88 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.59 @ OutletPC)
Storage: Kingston - HyperX Fury 240GB 2.5" Solid State Drive  ($90.10 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.33 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8GB Windforce OC Video Card  ($372.16 @ Amazon)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $1022.93
Generated by PCPartPicker 2017-05-19 11:04 EDT-0400
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856785
CPU: Intel - Core i7-6700 3.4GHz Quad-Core Processor  ($309.99 @ Newegg)
Motherboard: ASRock - H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($73.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($103.99 @ Newegg)
Storage: PNY - CS1111 240GB 2.5" Solid State Drive  ($81.98 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Newegg)
Video Card: Zotac - GeForce GTX 1070 8GB Mini Video Card  ($349.99 @ Newegg)
Case: Thermaltake - Core V1 Mini ITX Tower Case  ($56.98 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $1066.89
Generated by PCPartPicker 2017-05-19 11:11 EDT-0400
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856811
Total: $1022.93
If I could give this build two "Thumbs Up", I would.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856814
8 minutes ago, RaptorCandy said:
snip
OP wants to get the parts from newegg only.
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856828
Total: $1066.89
I'm liking this build up. I considered a few of these options. Price is still the same as it does not include the additional fans and CPU heatsink (I do not like stock coolers) but I still like it even though price doesn't really change as there is a good upgrade with cpu and gpu. Thanks.
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856851
there's a big 200mm fan on the core v1, you shouldn't have to spend extra on fans unless the temps get past mid-80 degrees Celsius. having an aftermarket heatsink for a locked CPU will be quite overkill so I'd recommend you just stick to stock.
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856894
Yeah the 200mm will help, I am looking to add fans for additional circulation/exhaust since it is a compact build. While the heat may never reach that, it is just a general preference even with locked cpu's. I'd rather spend the extra $80 to ensure a good (overkilled) cooled system. I do appreciate the list though.
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856916
you don't need to spend $80 just on cooling, that's a waste of money tbh. just get 1-2 80mm fans for the core v1 and you'll be fine.
https://pcpartpicker.com/product/2XDwrH/xion-case-fan-axpgf80wt $4 after rebates
https://linustechtips.com/topic/781811-first-micro-build/#findComment-9856929
