Hi guys,
Currently I am using a Asus ROG PG279Q, which in no way is a bad monitor. The 144 Htz really hertz, and I love it for gaming on my PC and Xbox One. Along with the PC and Xbox, I have a MacBook Pro 15". I find that the pixel density of the Mac is much higher (I mean it is higher) that the Asus. Any suggestions on content creation monitors under $1000? I would like to to be 4k or greater as well. \
Thanks!
https://linustechtips.com/topic/781554-best-display-for-content-creation/
10 minutes ago, django_keyes said:
I mean I would like an Ultrawide but 4k is important.
ok. For 4k, the Dell P2715Q is a nice option but it has thick bezels if you're planning on using a multi-screen setup. Also, 4k isn't very useful at 27" but since you weren't satisfied with the ppi on your asus, you will probably like it.
I would take a look at ultrawides though as they might be for you
