Powered Fan Splitter?
Go to solution Solved by W-L,
3 minutes ago, AjKawalski said:
Hello,
I was wondering if anyone knew of a fan splitter that has its own power but takes instructions from a motherboard header. I want to be able to control 6 fans from the CPU header, but the motherboard header can't provide enough power for all those fans.
Thank you,
If they are all 4 pin PWM fans you can get a power PWM splitter if not then you have a couple of options for 3 pin fans if you want a separate fan control system something like the NZXT grid+ V2 or Phanteks PWM input 3 pin DC voltage output fan hub.
http://www.phanteks.com/PH-PWHUB.html
Hello,
Thank you,
https://linustechtips.com/topic/781171-powered-fan-splitter/#findComment-9848614
That was exactly what I was looking for. The one that came with my case has no external power! so odd, anyway thank you!
https://linustechtips.com/topic/781171-powered-fan-splitter/#findComment-9848622
The fan splitter I use in my water cooling look is the Swiftech PWM 8 way splitter that works really well.
https://www.amazon.com/Swiftech-8W-PWM-SPL-ST-Way-PWM-Splitter-Sata/dp/B00IF6R4C8
CPU: 5900X   MOBO: MSI Tomahawk x570
MEM: G.Skill 32gb (2 x 16gb) 3600
GPU: Asus tuf oc 3080
May add the other bits of my system later on
https://linustechtips.com/topic/781171-powered-fan-splitter/#findComment-9849245
