first water cooled build
Go to solution Solved by MercuryRain,
FrozenCPU.com is a good place to go for water cooling components (in the US at least).
Custom loops are expensive.
When I was debating building a custom loop for my computer at home it came out to something like $300 minimum.
2 minutes ago, 9volt_battery said:
does anyone have any tips?
Do not cheap out and do research.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/781113-first-water-cooled-build/#findComment-9847803
Singularity Computers on youtube is a pretty good guy to watch on some of his older videos to get familiar with the kind of hardware you need - Pumps, Res's, Radiators, etc.  Could also go to him for inspiration on how to route your loop, although he works in all hardline tubing and does a lot of case mods.
Leak test the crap out of it, obviously.
https://linustechtips.com/topic/781113-first-water-cooled-build/#findComment-9847806
https://linustechtips.com/topic/781113-first-water-cooled-build/#findComment-9847819
