I say sorry in advance for bad English and my bad knowledge about computer!
Hi I have had some problem lately, Cpu have been overheating arounf 80-90 Celsius around 40% use. Problem i have come up with is that bios dont recognise my fans. And i Think its because of the Fan hub fron NZXT and Deepcool,
So my specs are
Motherboard: Z170 , bios vers 1206
Cpu: Intel Core i7-6700K Skylake
GPU: Msi Gtx geforxe 770gt 4gb
Cpu Cooler: Deepcool maelstrom 120t
2 x Corsair Air Series AF120 Quiet edition on the CPU Cooler
Case: NZXT H440W Silent Ultra
RAM: Kingstons Hyperx 2x 8 2133 Mhz
Harddrives 2 x 500 gb
SSD: Samsung 128 gb
Images :
Total 6 fans in the case , 2 on cpu cooler , 4 around the case
i have set the cpu coolers pump into CPU_OPT and the cpu fans to a hub and then to CPU_FAN, The other fans are connect to a FAN through NZXT HUB
So im wondering how to fix this overheating problem, in the bios i have set min to 200 rpm but cannot apply,
https://linustechtips.com/topic/780027-overheating-cpu-fan-problem/
15 hours ago, Uvalic said:
So i did that now, bios did find now one fan, but the still not the other so the problem its on the HUB?
might be. does the hub need an extra power connector?
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
No, so i tested everything,fans worked and i speed them up to Turbo(max speed) and saw that the coolingsystem does nothing to the cpu, at idle its goes upp to 80 C so i think its the pump that doesn´t working, day after tomorrow ill get a fancooler and see if it will work.
