Alright, so I need help on this one part of the motherboard...Connector:" F_Panel ". So, I have a Gigabyte GA-H110m-A motherboard and I have a Rosewill Dual Fans MicroATX Mini Tower computer case, Link: https://www.amazon.com/gp/product/B006BCK7RM/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 Now I dont know where to plug the cables in and I tried following the minimap below the connectors but that didnt work. My computer wont turn on because of this and I need to find a solution. Any Help would be appreciated.
Current Build:
i5 8600k @ 3.6 GHZ - Corsair H115i AIO
EVGA GTX 1060 6GB SSC Dual Fan
24 GB Corsair Vengence LPX @ 2400MHZ (3x8)
Windows 10 Pro 64 Bit
SPCC M.2 PCIe Gen3 x4 512 GB
SPCC SSD 128GB
Intel Optane 16 GB M10
WD 2.0 TB Blue
Gigabyte Z370XP SLI
EVGA 430W White 80+
Fractal Design Focus G Gray
Dell E2010H @ 60HZ
https://linustechtips.com/topic/779971-cable-help/
Just now, rogueone said:
Front panel connections should be in the motherboard manual. They should be marked and you follow the diagram in your manual.
 My motherboard did not come with a manual... It was used
Current Build:
SPCC SSD 128GB
WD 2.0 TB Blue
Gigabyte Z370XP SLI
EVGA 430W White 80+
Dell E2010H @ 60HZ
https://linustechtips.com/topic/779971-cable-help/#findComment-9833880
Go to your motherboard manufacturers website and download the pdf for your mobo.  I did that with my z87 board.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/779971-cable-help/#findComment-9833888
