Hi people, I work at a vet and people here are currently complaining on some specific pcs performance. The thing is, there are plenty here, and some of them work just fine, but there are two in particular that are way too slow.
Well, the thing is, that they both run on LGA775, so i figured that if I replaced the crappy ones' cpu and ram and level it with the ones that perform well, they should perform kinda the same. The thing is that they work on different chipsets, and I dont really know if that would be a problem
The PCs are used for basic web browsing, text editing and usage of a network program for entering patient data and stuff
The specs of both systems
The crappy ones
CPU: Intel Dual Core E2180
RAM: Kingston 1GB DDR2 @ 667MHz
MB: Asus P5GC-MX
Chipset: Intel Lakeport-G i945GC
The good ones
CPU: Intel Core 2 Duo E8400
RAM: Samsung 4GB DDR3 @ 1333MHz (2x2GB)
MB: Hewlett-Packard HP Compaq 8000 Elite SFF PC (It's a prebuilt system)
Chipset: Intel Eaglelake Q45
So, I was thinking on buying a couple of Core 2 Duo E8400 and some 2gb sticks of ddr2 @ 800MHz (I dont think jumping from ddr2 to ddr3 will make a big performance difference), to end with the following specs
The new hopefully not crappy one
RAM: Generic 4GB DDR2 @ 800MHz (2x2GB)
MB: Asus P5GC-MX
So, would this work ?
Thanks in advance for the help !
https://linustechtips.com/topic/778941-help-with-office-pcs/
8 minutes ago, wileywos76 said:
It would work but you'd be better of replacing them with a cheap mini pc from either Intel or Gigabyte
Or better yet wait for r3 and build several new $500 systems...
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823098
--SNIP--
The crappy ones
MB: Asus P5GC-MX
MB: Asus P5GC-MX
Technically, yes, it would work and help a lot, mostly in the RAM department. However, at this point, I'd recommend shelling out a few hundred bucks for a couple of MiniPC's from Lenovo, HP, or Dell with modern CPUs and hardware. They'll last a lot longer than upgrading these systems, and not be as expensive to maintain in terms of IT costs.
Dell 3050 Mini PC - http://www.dell.com/us/business/p/optiplex-3050-micro/pd?oc=s013o3050mffus&model_id=optiplex-3050-micro
23999-desktop-optiplex-3050-micro-pol-ma
Lenovo M710 Tiny PC - http://www3.lenovo.com/us/en/desktops-and-all-in-ones/thinkcentre/m-series-tiny/ThinkCentre-M710-Tiny/p/11TC1MT710Q
lenovo-thinkCentre-M910-M710-tiny-featur
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823115
7 minutes ago, Jrock said:
Get new systems...
Its pretty hard making my bosses spend money, I know that would be the best option, but pc hardware is pretty expensive here in Argentina
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823120
Me too.
I work at a computer company and my boss wont give me $600 for a new office PC.
Im stuck with a first gen i3 and 2gb of ram
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823126
Just now, Jrock said:
Me too.
yeah, im working with around 100usd budget per system, so this is what i came back with (i was thinking ssds, but i think ram is most important right now)
that would be the best option, but theyre way to expensive here
For example, an optiplex 3040 is a littble bit more of 1000usd here
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823136
Ah wonderful, sounds like Canadia land. We're not quite that expensive, but I've seen the $550 USD 6th gen i3 models sell for around $900 CAD, which is $150 more than they should be based on conversion.
https://linustechtips.com/topic/778941-help-with-office-pcs/#findComment-9823473
