My laptop is having problems with wifi, every connection gives No internet, when running troubleshooter it gives: The DNS server isn’t responding.
The other computer connects just fine. Tried manual setting router dns address and google public dns, also tried troubleshooter network reset.
By now I'm run out of options, any help is appreciated.
Oh and cable works just fine.
Legolessed - You don't have a 10 terabyte raid array in your phone?
 JaegerB  - F**king casual.
https://linustechtips.com/topic/778647-wifi-problems/
3 minutes ago, Daan101 said:
Does ethernet work if you have it?
Does wifi work on another network?
Use the dynamic settings on both IPv4 and IPv6?
Try turning off IPv4 and use only IPv6 and the other way around to?
Ethernet works just fine.
Wifi from other network gives same error
Both IPv4 and IPv6 using dynamic settings
Tried and same error
https://linustechtips.com/topic/778647-wifi-problems/#findComment-9819983
check your internet pool connector
(https://en.wikipedia.org/wiki/Connection_pool)
and if that does not work, try having a different conection, such as:
use external networking devices, the easiest is usb tethering (connect your smart phone and set up a hub using either a wired or wireless connection)
for more info, reply to this:D
https://linustechtips.com/topic/778647-wifi-problems/#findComment-9820008
