DARK SOULS 3 RESOLUTION ISSUES
By
Guest
in PC Gaming
in PC Gaming
Solved by Guest,
On 5/12/2017 at 5:02 PM, SeanAth0 said:Never Mind found how to run in safe mode and removed drivers will get back with you if it helps or does not
This Did not help however using the Souls Unqsueezed(A program that enables higher resolutions in Dark Souls 3 ) Seemed to have solved the issues
toxic_worper ·
Posted in New Builds and Planning4 -
2
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3
