I am running a 7700K i7 on a Asrock Z270 K6 Fatal1ty Gaming motherboard with a Corsair I55 AIO 16 Gig Corsair Vegence ram (3200) Ddr4 (2×8) with a updated bios and Windows 10 Pro. I overclocking in the bios and it takes yet when I go into Windows and check with Windows and Cpu-z it does not show my Overclocking I have all the latest updates for Windows and the latest bios even when I use the F1 asrock utility it doesn't take. I'm having the same issue with getting my ram speed to the correct speed. I have tried all the stock clocks on both ram and cpu and get the same results.
I am at a loss any help or advice is welcomed
Thank you.
https://linustechtips.com/topic/778104-7700k-oc-help/
Are you pressing F10 in the BIOS to save your overclocking profile? This may be a stupid question, but I had to ask.
Lian-li O11-Dynamic | i7-11700K |  MSI Z590 MAG Tomahawk | 64gb Ripjaws 3200MHz | 1tb Nvme SSD + 6tb HDD RAID | Corsair H115i Cooler | EVGA 850BQ PSU | RTX 3080ti TUF | LG C2 65" & Acer Nitro XV340CK Monitor
https://linustechtips.com/topic/778104-7700k-oc-help/#findComment-9813762
