Fan
Go to solution Solved by EnergyEclipse,
On ‎07‎/‎05‎/‎2017 at 4:12 PM, Carcarjg said:
No like a 12Omm case fan that i can put in my server cabinet.
Hello!
You could look for something such as this:
http://www.ebay.co.uk/itm/best-electronics-bt12038b1l-120mm-x-38mm-115v-ac-fan-3ft-power-plug-new/151029436981
then get some kind of adapter for the socket type suitable to your country's type.
Although, quite a few miscellaneous websites may be able to sell you a room extract fan to which is 120mm, to which plugs into a UK wall socket of some description. Although you may have issues finding a 'normal' dimension one since extractor fans tend to be thick.
Also, you can get 120m USB fans or 3/4 pin to USB adapters around, which may be an easier option for connectivity.
I hope this helps!
-EnergyEclipse
so basically a room fan?
go on amazon and search for it.. i dont know what form factor do you want the fan to be
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/776635-fan/#findComment-9795515
Hello!
I hope this helps!
-EnergyEclipse
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/776635-fan/#findComment-9805083
On ‎5‎/‎9‎/‎2017 at 6:54 AM, EnergyEclipse said:
Hello!
I hope this helps!
-EnergyEclipse
Ok thanks.
https://linustechtips.com/topic/776635-fan/#findComment-9835601
