HELP!! Computer will not turn on
By
levi7266
in Troubleshooting
in Troubleshooting
Solved by MrJarhead,
did you plug all the power pins in etc, power led, power, reset. if you havent nothing will happen when you press the power button.
these: they need to be plugged in correctly.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
7
michaelb198 ·
Posted in Peripherals2
