It's a DMS-59 connector (it's a dual monitor standard output -- so you would buy a DMS-59 to 2 DVI adapter and be able to output to two monitors from one port).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Just now, PCGal said:
OK thanks. Is it better than DVI?
It's dual monitor output -- it's designed to be converted to two DVI outputs.
PSU Tier List | CoC
Was about to comment this, but I wasn't sure of the actual name of the connector.
You can usually get an adapter for pretty cheap, maybe even free if you go local.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
