4 minutes ago, Adimantus said:
I need to flash the CyanogenMod v10.2 for the GT-I9300. I realized that Cyanogen closed so I need to find the latest stable build they released. I have been searching everything but I can't find something. Please help, any help is appricieted.
cyanogen is lineageOS now, they should have a ROM for that model on there
https://lineageos.org/
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
Just now, Adimantus said:
I do know that but I need the 10.2 version which was STABLE and its not provided under the name LineageOS.
to piratebay !!!!!!!
Home PC:
Work PC:
3 minutes ago, Adimantus said:
Well I tried going there but I found a bunch of nothing.
yh i can't seem to find it either, XDA is usually pretty good with this sort of thing, but they all point to official CM links that as you pointed out, don't work anymore. You might be stuck with Lineage unless you can find a sketchy MEGA link somewhere lol
Home PC:
Work PC:
Just now, Aytex said:
yes i was just there, you clearly didnt check the download link, the one that goes to cyanogen's website, which is down............
Home PC:
Work PC:
o, then I would try messaging some of the users if the have a original image
needle in a haystack, annoyingly i have a copy of 10.2 at home but its for I9195
Home PC:
Work PC:
I would like to get a STABLE version not a nighly build.
I would recommend posting on the XDA forums yourself and asking the same question there. You're much more likely to run into someone on the GT-I9300 forum that has a working link to the build you want than you are on LTT.
