Im haveing  weird things being told to me by different software. My bois tells me im running at 3.93Ghz which fluctuates and sometimes jumps to 4.8Ghz the BCLK at about 100.20 which jumps to 130 ish. The gigabyte app center tells me my BCLK is about 99.4 and the CPU runs at 3.9Ghz while the Gigabyte version of CPU-Z says the BCLK is 99.8 and my computer runs at about 3.92Ghz which is what task manager sais aswell. CPU-Z and task manager also show my cpu multiplayer as fluctuating depending on the system load while the Gigabyte app center doesn't. The gigabyte software original said thy BCLK was the 99.8 but over night it dropped to the 99.4 so i droped my voltage out of fear. Im running it as 1.4v at the moment but am going to try and bring that down some more. I have a R5 1600. What software am i suppose to believe.
https://linustechtips.com/topic/772998-ryzen-system-issues/
Top tip: Hammer + your french phone = beter forum topics and interaction with users.
25 minutes ago, Kabob71 said:
My bois tells me
Also, I'd say: screw the software and be happy with your 39 ghz CPU.
the CPU runs at 39Ghz
Finaly: everyone just hates them CPU-Z multiPLAYER changes.
On-topic:
I'd look at the temps and I'd ask myself: am I happy with the performance? Does it feel good enough?
I also doubt the gigabyte software is telling the truth, because it didn't show the multiplyer fluctuations.
https://linustechtips.com/topic/772998-ryzen-system-issues/#findComment-9754076
