Hello everybody. I read an article on PhoneArena about google releasing assistant sdk to developers... So my question is can custom rom/ Third party app developers use that SDK to get assistant support for their product.
I wonder because i use older devices (MM based moto 360 and G2 with custom rom but assistant is buggy for me maybe that good new SDK might help ?)
AMD Phenom II X6 1055T |Asus M4A88T-M |A-DATA 8 GB(4x2) @1333|Asus R7 360 2G OC|Asus TA-M1|Hitachi 7211 1TB|Fortron 460W|Windows 10 pro 64
https://linustechtips.com/topic/772647-assistant-sdk-for-60/
Google Assistant and Google Assistant SDKs are for Android 7 or newer.
It's not compatible with Android 6.0. You need to have Android 7.0 or 7.1 to be able to use Google Assistant and the Assistant SDK.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/772647-assistant-sdk-for-60/#findComment-9750214
Well that's what the article said it will be availible on 6.0+ devices.
https://linustechtips.com/topic/772647-assistant-sdk-for-60/#findComment-9750246
Oh rip. It might be available on 6.0 + but don't expect any kind of stability or performance.
If you had a newer phone running 7.0 then you might not have perf issues. Your phone is incapable of running 7.0 due to it running a 32 Bit CPU.
https://linustechtips.com/topic/772647-assistant-sdk-for-60/#findComment-9750580
Well incapable to run isn't exactly the right term here. That is what LG says that phone was not eligible for 6.0 but now running custom 7.1.1 and it's running 10 times better faster and smoother than its original firmware. I don't believe  every new phone beside flagships will come with a 64bit cpu
https://linustechtips.com/topic/772647-assistant-sdk-for-60/#findComment-9754303
