6 minutes ago, MajorFoley said:
I was wondering if i could use a backed up image of my computer as a boot for VMware? Just using the standard home use one not the pro version. The image i created was by using macrium reflect.
I think you should be able to, but the best way to know is to test it out.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/772231-vmware-and-images/#findComment-9745182
8 hours ago, Gargone77 said:
yeah, I think so.  Takes quite a while depending on the machine and how much stuff is on it.  Like hours...
uh... id say about 110Gb from a 120GB SSD that its compressed to about 80-90 i think? Should i make a backup of that or does it create an entire new file?
8 hours ago, KuJoe said:
+1 to VMware Converter, I've used it hundreds of times and it works like a charm. :D
Sure hope so... Saves me exchanging my  SSD's everytime i need to grab something off of it.
https://linustechtips.com/topic/772231-vmware-and-images/#findComment-9759403
