Need advice: Creating Nvidia Control Panel "preset"
Here is the thing: Im a gamer and i have 2 sets of displays. One is a triple monitor setup (great for race games) and a single, big gsync monitor (which is great for everything else).
Switching all the required settings back and forth is a real pain, so i was hoping to find some way of automating the work. I was hoping through a .bat file, but google seems to say thats not possible...
Can you help me find a tool that i could use to automate the work? I was hoping to make it possible with automated mouse clicks, key board short cuts, and the like. I have almost 0 skills in coding, and i looked into nvapi, but i couldnt make sense out of it... Help with some lines of code, would be much appreciated!
Settings i need to change:
- SLI settings (3D max vs Surround, including bezel settings, as well as setting the 2nd GPU as prefered for PhysX)
- Setting the primary display (required for gsync and this decides on which display the games show up)
- Position of the displays on the desktop, since the order of the displays is important too
Some info about my pc:
2 GTX 780 Ti, 3x 1080p and 1 gsync 1440p screen.
Upgrading my GPUs later this year with a single GTX 1080 Ti, so...
Who knows a good program i can use? Tips? Advice?
