I'm looking for recommendations on a home security solutions.
Everything that I find that is recommended requires some sort of monthly or yearly subscription.
However, I just want to be able to feed video into my own home solution with the responsibility on me to call the authorities.
Just having an audible alarm would make me feel 100% more safe.
I'm wanting a setup that may include:
Audible alarm
Outdoor and/or indoor camera
Door/Window opening sensors
Room motion sensor
App/Keypad controller
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/771379-home-security-solution/
https://nest.com/camera/meet-nest-cam-outdoor/
https://ring.com/video-doorbell-pro
Not perfect, but if you want something more in depth you should do a lot of research into it. I have a friend who rigged a security system up himself through his network, and wired it into an hold fog horn or something? It's loud. That I know.
Better dead than Red.
Pheonix
CPU: i5 2500k @ 4.6ghz Mobo: Asrock Z77 Extreme4 RAM: G.Skill 16gb of DDR3 @ 1600mhz GPU: Gigabyte GeForce GTX 1060 6gb Extreme Gaming PSU: EVGA 700B Storage: 480GB SP SSD and a 960GB Ultra II Sandisk. Cooler: Cryorig H7 Case: Phanteks P400.
https://linustechtips.com/topic/771379-home-security-solution/#findComment-9734888
One of those companies makes motion sensors as well.
Pheonix
https://linustechtips.com/topic/771379-home-security-solution/#findComment-9734890
Thank you for your input.
https://linustechtips.com/topic/771379-home-security-solution/#findComment-9735063
2 minutes ago, yathis said:
Do you want a feed to your cell phone?
It would be great if I could use an application to manage the system or stream the camera.
It isn't necessary if it saves on price.
https://linustechtips.com/topic/771379-home-security-solution/#findComment-9736961
3 minutes ago, yathis said:
Well there would be something that would stream it via internet or cell towers. Just a matter of you want it 100% all the time or only if the alarm goes off.
If there is something you can recommend to supplement either of these situations, please do.
https://linustechtips.com/topic/771379-home-security-solution/#findComment-9736991
